has anyone made any mapsfor the Novation sl controllers?
  • jerms
    by jerms » Fri Jun 08, 2007 11:46 pm
    I just purchased one and I will make some maps soon and make available, but woould this work with the automap function? That would b e sweet!!!!
    plax
    by plax » Sun Mar 08, 2009 11:04 pm
    it seem that you can create one template with the remote template editor
    http://www.novationmusic.com/support/so ... l_compact/
    My knowledge about midi is not sufficient enought to create one but maybe somene could try, it would be appreciated, maybe a member of garagecube team could succed.
    macbook intelcore duo 2 GHZ - 2 giga de ram
    g4jon
    I have map
    by g4jon » Tue Mar 10, 2009 10:35 pm
    send me your email address I send you a map to upload to the remote sl via the template editor
