Mid Clock BPM problem
  • bblount
    by bblount » Mon Jun 11, 2007 10:25 am
    I am trying to setup Ableton and or Traktor to transmit a midi clock signal for BPM. Everything seems to be set up ok for the clock out of the programs - it is showing the correct bpm in Ableton. When I click on the use midi clock in Modul8 (version 2.5.4 on a Intel Mac Mini) the BPM number registers all kinds or weird numbers. I even tried setting a firewire network out of the Mac Mini to my Powerbook G4, and sending the midi clock over firewire, but the same thing happened in Modul8 with that set up too. I just can not get a steady BPM with the midi clock.
    On my mac mini, I got this error:<b>
    if pause == False:
    if midiClock and type == 'MIDI' :
    if param ['message'] == 'REAL_TIME_START' :
    sharedDict['BMP_POSITION'] = 0.0
    if param ['message'] == 'REAL_TIME_CLOCK' or param ['message'] == 'REAL_TIME_START' :
    midiCount += 1
    if midiCount == 1 :
    midiTimeStart = param['timestamp']
    elif midiCount > 24 :
    timeDiff = ((param['timestamp'] -midiTimeStart)/1000000000.0)
    if roundValue :
    speedTest = round (60 * (1.0/ (timeDiff)))
    if speedTest == speedBackup : speed = speedTest/60.0
    module.setAttribute('midiBPM','caption','BPM : ' + str(int (speed*60)))
    module.setValue('speedKnob',0,speed)
    module.setValue('speedBar',0,speed)
    module.setValue ('UIbpm',0,int (speed*60))
    else :
    speed = 1.0/ timeDiff
    module.setAttribute('midiBPM','caption','BPM : ' + str(speed*60))
    module.setValue ('UIbpm',0, speed*60.0)
    speedBackup = speedTest
    midiCount = 0
    midiTime = 0.0
    elif param ['message'] == 'REAL_TIME_STOP' :
    speed = 0
    midiCount = 0
    midiTime = 0.0
    module.setAttribute('midiBPM','caption','BPM : 0')
    module.setValue('speedKnob',0,0)
    module.setValue('speedBar',0,0)
    module.setValue ('UIbpm',0,0)
    elif pause== True:
    speed = 0
    <b>
    maybe that will help diagnose the problem.
  • bblount
    by bblount » Mon Jun 11, 2007 10:34 am
    Well,
    It seems that having Airport active slows things down - now my Traktor program is tranmitting 125bpm from the Mac mini over firewire and Modul8 on my Powerbook is registering 114 or 122 bpm - it will jum from 114,122,114,122 etc...My latency is running about 3ms.
    Also, is there any way to override or correct the midi clock?
    Thanks,
    Brian
Users browsing this forum: Baidu [Spider] and 16 guests
