triple head 2go problem.
    deepvisual
    by deepvisual » Tue Jun 19, 2007 11:09 am
    all seems well on the mac front - the desktop extends nicely across all 3 screens.
    but when I enter full screen in modul8, the image shoots off to the far right hand side and is stretched x 3 horizontally.
    I've tried all variations of preview, and advanced output.
    for some reason the screen size and centre are all way out
    help???
  • decolora
    by decolora » Wed Jun 20, 2007 11:42 am
    i think you have to set up in prewiew(preferences) option 4:1
    haye
    by haye » Thu Jun 21, 2007 1:52 am
    first of all you don't need to use the advanced output feature, because your three screens appear as one to the system. just switch to fullscreen.
    concerning the preview window, i got best results by setting the aspect to "free" and dragging it manually to 1024*256.
    hope this helps! have fun.
    deepvisual
    by deepvisual » Thu Jun 21, 2007 12:43 pm
    thanks for the help.
    in the end it looks like it was a TH2G problem.
    after taking the system apart and re connecting everything, I set the preview to 1024x 256 and it worked perfectly,
    as I can't repeat the problem in M8 it looks like TH2G got a little confused.
    unfortunately I have now run out of excuses and will have to buy a HDV camera to make footage for the much bigger screens.
    thanks again
    Gary
    by boris » Fri Jun 29, 2007 3:24 pm
    Yes advenced mode is only for tower computer with several graphic card (up to 8 output).
    For using a matrox just change your preview panel to 8/3 for a dualHead and 4/1 for a tripleHead.
    This informations is also on the user manual p.29 :roll:
    deepvisual
    by deepvisual » Sun Jul 01, 2007 3:37 pm
    I;ve since found out that the problem comes from using antialias.
    if this is switched on with TH2G modul8 becomes very confused.
    switch it off and everything is fine.
  • Akira
    by Akira » Tue Jul 03, 2007 11:38 am
    The triple/dual cards from MAtrox are shit at certain resolutions.
    IF you stick to what they say it works, you shouldn't have this problem, I guess.
    They are so unstable that it hurts. I hope they upgrade them, the idea is good but they have many problems.
