crossfader black fade out problem
  • theinsanemulatto
    by theinsanemulatto » Wed Jun 27, 2007 12:23 am
    I screw and chop (see DJ Screw) music videos with sound. To be able to do this I have to use the crossfader with both fading buttons on so the sound and video both switch when I crossfade from clip one to clip two. My problem is that when I am chopping(rapidly crossfading from clip one to clip two) I notice a little fade to black. It is not a clear dissolve between clips like when you use the fader. Is this solvable?
  • helium_micro
    by helium_micro » Wed Jul 04, 2007 2:25 am
    The same thing is happening to me when I both Group A and Group B set to fade. If I set only Group A to fade then the "black out" issue is resolved, but that doesn't help you with the sound issue. Sorry. This only started happening recently. Before when I had both A and B set to fade it worked as it should - no fade to black inbetween. Any ideas why this is happening?
    H - E - L - I - U - M
    www.helium-visuals.com
Users browsing this forum: No registered users and 58 guests
