Advanced Output no Save Function & Limitation
  • toby
    by toby » Tue Jul 17, 2007 2:18 pm
    First there is no way to save the position and size advanced output on desktop.
    The Import & Export Feature dont save the size and the position of outputs only the clip-frames are stored.
    By energie fallout or modul8 crash we have to do the set again by hand.
    We plan to use a LED-Wall with one DVI-IN which needs a 3 row tile splittet source.
    So we cant go Fullscreen.
    Second:
    If i specify a Clip-Frame in Advanced Output with 800pix wide and for example 600 high you can scale this output-frame with the mouse to exaktly this size. 800x600
    But if you use more then 800 pix wide - for example 1024x600 the desktopframe gets scaled down to 800x468. why ?
    Re: Advanced Output no Save Function & Limitation
    by boris » Tue Jul 17, 2007 9:47 pm
    Advence output working prety well, but you need to anderstand a bit more the software.
    I already answer to your questions here :
    http://www.garagecube.com/forum/viewtopic.php?t=1709
    PLEASE : dont send the same thing at twice.
    Second:
