Film Clips freezes shortly at the end before loopng.
  • blissomatic
    by blissomatic » Thu Aug 09, 2007 7:27 am
    As the subject says, I have a problem with clips momentarily freezing up in the end before looping from the beginning again. The clips are encoded as Mjpeg at 75% quality. I use a MacBook and at the time was playing the clips from the internal drive. All the clips showed the same problem.
    What could the problem be?
    Thanks for the help.
    /Henrik
  • moonbase
    by moonbase » Thu Aug 09, 2007 12:46 pm
    Hi, do the clips loop ok when played in QT player, outside of M8, or does the freeze moment happen there also?
  • KIer
    by KIer » Thu Aug 09, 2007 4:53 pm
    I have exactly the same problem.
    The clips looped ok when played in QT player.
    I'm using OSX10.4.9, Modul 8 2.5.4, QuickTimePro 7.1.6 on a 2.16GHz IntelCore 2Duo iMac with 2GB Ram, 256MB graphic and runs the clips on the internal 7200rpm hard disk.
    hope someone will have a solution for this problem.
    thanks in advance.
    Kier
  • blissomatic
    by blissomatic » Thu Aug 09, 2007 6:42 pm
    I have now tried to convert the clips in mpeg streamclip, quicktime pro and compressor.
    I have tried Mjpeg a and b, photo-jpeg, and DV PAL. I have tried different resolutions and different logins in OSX.
    I still get the brief freeze at the end of the clip. It's very disturbing indeed and ruins a lot of my ideas which are very much built on looping :)
    Nobody have any ide to a solution?
    Would be great!
    Thanks. Henrik.
