i was told of a VJ performance here in Hamburg the other day and someone said it was done by modul8 application. although i have heard much good, the friend who was there said about a switching flicker (he assumed the unwanted effect came from previewing resp. switching thru the internal banks while still actually showing another bank...is this a problem known by frequent users of modul8?
thanks for any infos on this!
I have a feeling the answer to your question was not forth coming because of the answer is yes/no/maybe/never/always.
Do to the way the program can handle media many, many factors can lead to this kind of output. I will list in my own order from most to least important.
1. Computer Power ( RAM, HD Speed, GPU, CPU)
2. Media encode settings ( poor encoding practices will spoil your day)
3. Media Length (put 30 Min clips on DVD or trim it!)
4. Style ( if you have to ask you don't have it, not to worry though I see at lot of paided Vj's with no Style)8)
All that being said this program is the only one I have used that is so much more then clip playback. You can really tweak it and actually create live!
I use first gen Macbook Core Duo 2.0 Ghz, 2.0 Gig RAM, 5400 RPM Bus Powered USB 80 Gb, V-4 and Camera Guy several days a week. Does it hiccup sometimes? Yes! Does that effect my performance? No!
If you want to charge lots of money for timed, perfect performances then rackmount some G5's or MacPros. If you want to have fun and mix on the fly, Macbook or Macbook Pro will get your there.
When I pull out all the stops I'm running at least 2 computers (up to 4) and up to 7 cameras. If it hiccups I got coverage.
