Scratching problems
  • Kemuri
    Scratching problems
    by Kemuri » Fri Aug 24, 2007 3:22 pm
    Hi!
    I run the 2.5.4 version. I have a problem with the scratching function. I mapped all the two knobs to a MIDI controller but it's totally useless. It's too fast. I mean if I try to make some scratch with the controller, for the smallest touch it moves like a "mad-cow". You cannot see anything from the loop just some frames. I cannot make smooth/slow scratches. I prepare "all frame is key frame" so it wouldn't be a problem.
    Can anybody help?
    Thanks in advance.
    Kem
    by sigmasix » Fri Aug 24, 2007 9:35 pm
    the size of the knob is mapped on the legth of your movie. if your movie is long, a small move will jump in the movie. with a 5 sec loop, it's correct I think
    maybe you can try to make a module that decrease the steps of the knob..
