Modul8 2.5.5 Beta
    by boris » Sun Sep 30, 2007 4:00 pm
    Please send your crash report FILE
    [Your user directory]/Library/Logs/CrashReporter/Modul8.crash.log
    and your report, setup, etc to the SUPPORT :
    support --at-- garagecube --dot-- com
    Thank you.
    olim wrote:Hi Boris,
    I have a macbook pro core 2 duo with 2.33ghz and 2gb ram.
    I was using PNG files (up to 12KB) in 4 or 5 layers at same time. All files were reacting to the sound input (Auto Move + Auto Scale).
    I had applied for each layer a different Transformer, filter, scale and rotation.
    Hope this help.
    thanks.
  • tvjunkie
    by tvjunkie » Wed Oct 17, 2007 12:55 am
    hi guys :wink: ,
    I have a simple question
    The modul8 ready for Mac os x 10.5 Leopard
    Or simultaneously released new versions to the new operating system?
    Compliments
    Leandro Pita
  • RickRobiN
    by RickRobiN » Wed Oct 17, 2007 3:07 am
    :D
    testdrive for 4 hours with this beta on a g5 quad and 3 outputs and 1920 hd footage, no problems at all... Keep on the good work!
    cheers RR
  • bratch
    by bratch » Wed Oct 17, 2007 9:55 am
    :D multiprojection is OK now ! Thanx guys !
    Mac Pro 2.66
    M8 V2.5.5 beta
    QT 7.2
    HD Raid 0
  • freespirit
    by freespirit » Wed Oct 17, 2007 5:46 pm
    Modul8 seems to work on the Beta of Leopard that I'm using, didn't have a lot of time to play with it but what I could try worked as expected.
  • macman81
    Leopard = OK
    by macman81 » Mon Nov 05, 2007 3:39 pm
    Everything works fine for me in Leopard. No issues in 2.5.4. I'm running the official public release build, 9A581.
    deepvisual
    leopard
    by deepvisual » Tue Nov 27, 2007 10:28 am
    only problem I have is the previews in the clip window have no green in them..
    everything else seems fine.
    clips are all H264
  • ylandsman
    by ylandsman » Sun Dec 09, 2007 10:24 pm
    Hey Boris,
    Any word on when 2.5.5 will be released?
  • vjavil2511
    on pc.. its can work?
    by vjavil2511 » Tue Dec 18, 2007 5:18 am
    by sigmasix » Tue Dec 18, 2007 10:26 am
    modul8 doesn't work on windows
  • SUN
    by SUN » Sun Dec 23, 2007 6:08 am
    :D 2.5.5
    Looking forward to using it!
    wygiwys
    by wygiwys » Tue Apr 08, 2008 10:49 am
    Any news? It has been quite a while since this beta was released...
    What You Get Is What You See
    WYGIWYS.tv
  • garageRoot
    by garageRoot » Tue Apr 08, 2008 6:04 pm
    Beta 3 is is here :
    http://www.garagecube.com/forum/viewtopic.php?t=2155
    wygiwys wrote:Any news? It has been quite a while since this beta was released...
