Live video in size?
  • JJHP3
    Live video in size?
    by JJHP3 » Fri Aug 31, 2007 6:25 pm
    Hi All
    I'm using latest (not beta) version on a MBP 2.33 osx 10.4.9 I am using a TH2Go, though the problem, if ther is on,e is evident without the matrox unit attached. My preview size is 4:1 I am a bit confused about the size of my incoming NTSC video. It seems a bit too small compared to a standard 640 x 480 test image. I have to rescale the live input -every time- I open the project. The program doesn't save the location and size. I have looked at all my possibilities (QT prefs etc) and nothing seems to change it. I also use Isadora on occasion and find that it brings in the video correctly. Of course it also has a "video settings" window and resizes my DV input to 640 x 480.
    The system I'm using for an upcoming dance show is two DV cams into an Edirol V-4 into a Canopus 55 into M8 out to TH2Go.
    Thanks
    John
    deepvisual
    by deepvisual » Sat Sep 01, 2007 12:27 pm
    have you had a fiddle with the source and capture settings in preferences?
