whitch grafic processor to choose?
  • donleo
    by donleo » Mon Sep 10, 2007 10:33 am
    can you help
    i like to use modul8 for mixing video [not using effects]
    only key text over the images.
    and mixing video images..
    does itmake a lot of difference to buy :
    NVIDIA GeForce 8600M GT grafische processor 128 mb
    or
    NVIDIA GeForce 8600M GT grafische processor met 256 mb
    and 2gb or 4gb memory
    tanx
    by sigmasix » Mon Sep 10, 2007 1:21 pm
    please do not double post your messages :roll:
  • donleo
    by donleo » Mon Sep 10, 2007 8:40 pm
    yep, but still no answer, so at witch place should i ask my question...
  • sonicslice
    by sonicslice » Mon Sep 10, 2007 9:49 pm
    Well I use a macbook which has at most half of the lowest spec of both of those cards, and this is shared with the main system RAM of 2gig, I don't find it difficult to use modul8 to do some fairly complex tasks, maybe 8 layers plus pixel effects (not core image or FF) etc. and that kind of thing, all at 640x480 pjpeg footage, so either of those will be fine for simple stuff, but I imagine that if you want to get into the more advanced stuff or any of the effects in the future then the 256mb card will be the most future proof.
