Mapping going missing
  • Larky
    by Larky » Thu Sep 13, 2007 9:36 pm
    IGNORE THIS, FIGURED IT OUT.
    Hi all. OK, I'm running into an odd issue. My MIDI mapping keeps vanishing at random points. I set up a device, all is working and then for no reason all the mapping to everything but the layers will vanish. I normally set my mapping as default, but it does it if I save to a file also. This is obviously a pain, any ideas?
    I'm using a Korg Kontrol 49 and also a Novation Remote Zero.
    Edit: Actually, MIDI in general seems to be going mad. I am using Layerset+Position. As far as I cna tell, it used to be that if I had layer 1 selected, and I used Auto Move to make it jiggle around, if I then went to Layer 2 the Auto Move would be greyed out as Layer 2 isn't using it. But now it's on all the time, meaning I have no idea what is going on as I get no visual clues. Basically, I want to be able to select a layer, alter bits of it, go to another layer, alter bits etc, and when I select a layer only bits affecting that layer should be visible. Also, why do I now have to set MIDI controls on every function for every layer, before I could set it once and it spanned across layers. Is this a MIDI device issue, am I going mad, or have I picked up the computer equivilent of lunacy?
    A.
    EDIT: Sorted it, can't say how as it involved a format! Anyway, template for the Novation is at: www.ingenieursonline.co.uk/IngenieursM8.zip
Users browsing this forum: Google [Bot] and 15 guests
