problems with logical record
  • pablosanz
    by pablosanz » Thu Sep 20, 2007 9:17 am
    hi!
    I´ve just switched to the new beta of Moudl8 and I have problems when rendering logical recordings. Modul8 renders a completely black output. I´ve done different tests with several recordings, codecs, time ranges within a recording, etcetera; all of them with negative result. I can fforward the recording with the timeline ant it seems to be ok, but render doesn´t work at all.
    I´m on a Macbook Pro 15" 2.4ghz 2gb ram.
    Altough I never posted here on this topic,with the previous versions I have been having some problems with logical record too... It seemed like Modul8 wasn´t able to manage the changes in layers and parameteres at time to appear in the render, and I obtained some missing and delayed layers. Trying to leave the timeline in the starting position of the render and rendering only some ranges of the recording, I managed to do the thing most of the times, altough it was such a waste of time. Also, it didn´t recognize the changes of media clips done in the Mask(Global) module during the recording, so I couldn´t use this with different clips in the same recording. I perceived speed changes too in the rendered videos.
    thanks!
    by boris » Sat Sep 29, 2007 4:01 pm
    Please About Beta versions send an email to the support or use this tread :
    http://www.garagecube.com/forum/viewtopic.php?t=1775
    Thank you.
    by boris » Sat Sep 29, 2007 4:03 pm
    What's your version of quicktime ?
  • pablosanz
    by pablosanz » Sat Sep 29, 2007 7:06 pm
    QT 7.2.0 <-----
    thanKs
  • ruben117
    ANOTHER PROBLEM
    by ruben117 » Mon Oct 12, 2009 4:56 pm
    hey folks.
    i think i'm making a fundamental mistake which isn't too hard to fix but i just don't get it done:
    i'm trying to use the "logical record" function on a setup that's supposed to run on 4 external HDTVs. I've tried different codecs (prores, foto-jpeg, animation) always with the resolution 5120x720 (4x 1280x720 for the 4 TVs). There's not really a problem with the different layers (as often mentioned by other poor guys) but the material is not at all scaled or has anything to do with the 4 output windows... it's just the source-resolution in the middle of the recorded videofile.
    what do i have to do to get modul8 to just record the stuff that's shown on the output-screens and stitch it together as one 5120x720 file?
    should be possible, shouldn't it?
    greetz and thx in advance!
    EDIT:
    Okay now i also got problems with a completely black output or missing layers... gdmnit.
