Modul 8 Normalize
  • SanderK
    Modul 8 Normalize
    by SanderK » Fri Sep 28, 2007 5:36 am
    Hi Guys
    I have rendered all the clips in 320x240 and each time I choose a clip it will be shown just half because the output resolution is 640x480. Is it possible to switch the normalize button already on when I create a new layer? I'm afraid that I will forget to switch it on, on a gig and for my purpose it should be always switched on.
    thx
  • VJnutcracker
    by VJnutcracker » Fri Sep 28, 2007 1:43 pm
    Same here, i render at 512x384 (half of 1024x768) and get the same problem.
    An option in preferences would be handy.
  • Lupin
    by Lupin » Fri Sep 28, 2007 2:48 pm
    an answer to your this issue is to use the master scale property bar and zoom until you reach the correct size.then each time you'll load a media at half resolution it will be displayes at the correct size.
    by boris » Sat Sep 29, 2007 12:13 am
    You can also use the "default layer" module (on the online library)
