[Feature Request] Disable Exposé only for the output
    Anome
    by Anome » Wed Oct 03, 2007 10:07 am
    I talk about this pb in this thread : http://www.garagecube.com/forum/viewtopic.php?t=1793
    To sum up : during vidzeo projection, it seems impossible to use Exposé as it fades the output window (and, of course, do the usual job : displaying all the windows).
    I d really appreciate to use Exposé during video live.
    Cheers.
  • sonicslice
    by sonicslice » Wed Oct 03, 2007 9:16 pm
    Is expose not part of OS X, and therefore the feature request should really go to apple as opposed to garagecube?
    Just a thought.
    Anome
    by Anome » Sun Oct 07, 2007 3:02 pm
    i dont think apple ll care about such a feature but modul8 team could ...
  • sonicslice
    by sonicslice » Sun Oct 07, 2007 7:12 pm
    ? how exactly?
    Anome
    by Anome » Sun Oct 07, 2007 7:14 pm
    dont know to be honest : just looking for a solution ...
  • sonicslice
    by sonicslice » Sun Oct 07, 2007 7:33 pm
    How about organise your sessions better?
    Anome
    by Anome » Sun Oct 07, 2007 7:39 pm
    that's simple : is there a way to use both modul8 and exposé at the same time without fading the output window ? the answer seems to be "no" for instance.
    so i ask the modul8 team if they can fix this pb ... i dont wanna change the way i m working, i just wanna know if it could be possible in the a next release.
  • sonicslice
    by sonicslice » Sun Oct 07, 2007 7:59 pm
    I'm still trying to comprehend why you are asking one developer to fix the problems in another developers software - you may as well be asking microsoft to fix the issue you have in OS X.
  • Lupin
    by Lupin » Sun Oct 07, 2007 9:09 pm
    what you are asking is impossible with the current OS.
    you should ask this to apple core developers.
