Is it possible to...
  • nicksmix
    by nicksmix » Tue Oct 09, 2007 12:02 am
    Is it possible to re-arrange the order of the Pixel FX?
    For example, I want to add noise to the blur effect, instead of blur to the noise effect... :?
    can it be done?
    thx
  • Lupin
    Re: Is it possible to...
    by Lupin » Tue Oct 09, 2007 6:01 pm
    can it be done?
    thx
    not on the main interface but you can use the Filter (layer) module where you can stack up to 4 effects including, noise, saturation lightness luma , blur and so on
