Convert .swf files to flash 5 or .mov!!
  • Mighty Rye
    by Mighty Rye » Wed Oct 17, 2007 2:30 pm
    Hey Guys!
    Now i searched for about 2 hours, and found many answers about how to convert .swf files to flash 5 or video-formats. But nothig seemed to work.
    I have Flash 9.0, but when i load a .swf into it, i cannot convert or export files?! How do i do that? There are not buttons to export or convert in "File" - or any of the other.
    Help me please! (:
  • Mighty Rye
    by Mighty Rye » Thu Oct 18, 2007 2:31 am
    .. why can it be, that Modul8 says for some of the files i try to import: "Media not supported". They are all .swf-files, but only some of them works with Modul8.
  • DJSare
    by DJSare » Thu Oct 18, 2007 8:20 am
    In quicktime if a option in the pref. to activate flash files.
    Open flash files in quicktime and save. After save have the file
    a .mov and you can open in Modul8. But not all flash files are
    supportet to make it to work.
    http://cat.xula.edu/tutorials/animation/qt.php
    http://victor.transformadora.com/Oreill ... h26_05.htm
  • Mighty Rye
    by Mighty Rye » Thu Oct 18, 2007 7:06 pm
    But how can it be, that not all .swf-files can be played?
    by sigmasix » Thu Oct 18, 2007 7:52 pm
    you cannot play swf files that have actionscript in it and/or are compressed.
  • Mighty Rye
    by Mighty Rye » Fri Oct 19, 2007 7:57 am
    yeah, but what is the solution then? how can i convert them?
    by sigmasix » Fri Oct 19, 2007 8:40 am
    you must modify your .fla file to work without actionscript and change you publish settings to make an uncompressed .swf file
  • Mighty Rye
    by Mighty Rye » Fri Oct 19, 2007 4:52 pm
    but i only got the .swf file ? which app can debug the actionscript, when i only got the .swf file?
    by sigmasix » Sat Oct 20, 2007 9:46 am
    you can try to import your swf file into flash, sometimes it works
    fati.V
    by fati.V » Sun Oct 21, 2007 10:35 am
    Mighty Rye wrote:but i only got the .swf file ? which app can debug the actionscript, when i only got the .swf file?
    Perhaps you have to do your own swfs files ;)
  • Mighty Rye
    by Mighty Rye » Tue Oct 23, 2007 10:31 am
    fati.V
    by fati.V » Wed Oct 24, 2007 10:42 am
    RTFM ;)
    File/Export/Export Animation :roll:
  • mowgli_uk
    by mowgli_uk » Fri Oct 26, 2007 3:13 pm
    You need the fla not the swf to edit it.
    Modul8 will only work with flash5 files.
  • Mighty Rye
    by Mighty Rye » Fri Oct 26, 2007 3:16 pm
    by sigmasix » Sat Oct 27, 2007 1:35 pm
    I didn't mean "open it in flash" I meant IMPORT it IN a document. then it should works (except all actionscript I think)
