Layer transparency modes (like Photoshop)
  • deckard97
    by deckard97 » Sat Oct 20, 2007 2:52 am
    is there a way to (or fake to) emulate the layer transparency modes like in Photoshop?
    Overlay, Multiply, Darken, LIghten, to name a few.
  • Lupin
    Re: Layer transparency modes (like Photoshop)
    by Lupin » Sun Oct 21, 2007 8:46 pm
    first crate alpha channel movies then apply chroma filters or any effects with the filter (layer) module
    deepvisual
    by deepvisual » Tue Oct 23, 2007 4:38 am
    http://www.vjfx.com/vjfx_store_sys.php?op=VJFXStore
    take a look at mix with inks.
    this may be what you are looking for.
  • deckard97
    by deckard97 » Wed Oct 24, 2007 2:41 am
    Those VJFX could come in handy.
  • treas
    by treas » Thu Nov 08, 2007 2:10 am
    but i think it doesn´t work with m8 cause you need
    the possibility to have 2 inputs at the plugin.
    did you try it? if it works it would be great.
  • Lupin
    by Lupin » Thu Nov 08, 2007 11:33 am
    VJFX ink plugins can't be used with modul8. inks are blend modes for the moment the only blend mode you have in M8 is inside the Mask (global) module. each layer independently don't have blend modes.
  • sonicslice
    by sonicslice » Thu Nov 08, 2007 11:36 pm
    You could create a QTZ file to do this.
