modul8.setValue ctrl_layer_focused question
  • anomad
    by anomad » Sun Oct 21, 2007 11:20 pm
    I'm trying to write my first module and am having some trouble getting things working the way I want them to! :D I'm more of a perl/php programmer, so I'm still trying to grok python...
    I'm using a uc-33e controller and I want the numeric keypad to server 2 purposes:
    If the layer is not in focus, set the focus to that layer (but do not hide/unhide)
    If the layer is in focus, toggle hide/unhide.
    So, if layer 1 is active and not hidden and layer 3 is hidden, I could press the '3' button to focus on layer 3 and change some parameters then press the '3' button again and have it displayed (not hidden)
    I am able to hide/not hide the currently focused layer, but I am unable to change the focus of the layer (unless the main window doesn't update the new layer with the orange hightlight)
    Could this be related to http://www.garagecube.com/forum/viewtop ... yerfocused ? Was this fixed ?
    The code I'm using with debug statements looks like this: (in DirectEvent)
    Code: Select all
    if type == 'MIDI' and param['channel'] == 1 : ##print 'Midi Key from uc-33e:' , param['param1'] ## On the uc33e, P01 sends the numeric keypads at button 1 = midi message 19, button 2 = midi message 20, etc. myDebug = True myLayer = param['param1'] - 18 if modul8.getValue('ctrl_layer_activated', myLayer) == True: if myDebug : print "Before : " print "Layer " , myLayer, " : focus : ", modul8.getValue('ctrl_layer_focused', myLayer) print "Layer " , myLayer, " : hidden: ", modul8.getValue('ctrl_layer_hidden', myLayer ) print "Layer " , myLayer, " : active: ", modul8.getValue('ctrl_layer_activated', myLayer ) if modul8.getValue('ctrl_layer_focused', myLayer) == False : modul8.setValue('ctrl_layer_focused', True, myLayer) else : hideToggle = modul8.getValue('ctrl_layer_hidden',myLayer) modul8.setValue('ctrl_layer_hidden', not hideToggle, myLayer) if myDebug : print "After : " print "Layer " , myLayer, " : focus : ", modul8.getValue('ctrl_layer_focused', myLayer) print "Layer " , myLayer, " : hidden: ", modul8.getValue('ctrl_layer_hidden', myLayer ) print "Layer " , myLayer, " : active: ", modul8.getValue('ctrl_layer_activated', myLayer ) print "-------------------------------------------------------------"
    Thanks in advance to anyone who may be able to shed some light on this issue!
    -james
    (a nomad. )
    by boris » Wed Oct 24, 2007 11:30 am
    The keyword ctrl_layer_focused is read only.
    You need to use the keyword : ctrl_layerStack_focusPosition
    Re: modul8.setValue ctrl_layer_focused question
    by boris » Wed Oct 24, 2007 11:32 am
    Yes it is fixed.
