there is a module with a equalizer with column bar that move with the music?
thanks... i downloaded the files...but only the Analog Vu and Digit Vu work....I downloaded the free Quartz Composer files for CoreMelt VU. The VU meter ones work ok, but I have had no luck with the EQ. Maybe others here can prevail were I have not.
http://www.coremelt.com/
any solution?
thanks
This is because they are made to work with VDMX, the audio side of the qtz file comes from VDMX using the VDMX FFT and not the in built (not as good) FFT in qtz. There are a lot of controls that you can't use in modul8 on all of them - these appear if you load it into VDMX - they can all be easily edited to work in modul8.Well i tried the analog Vu and digital VU and it works fine. i jsut exported them into quicktime movie from quartz composer an then imported them into Modul8 . but the 6 or 13 bands equalizer don't work on my computer... i do'nt know why, i'll digg into this tonight
so 13 bands equalizer can works into modul8?to select the band you want to bind to your equalizer select go to tu vu macro then find the blue box "audio inpu" then link the spectrum output to the structure Key member module then in this module as the Key input parameter enter "band_0" for band 0 this audio spectrum values goes from band_0 to band_12.
then link the output paramter "Member" to the Multiplexer in the Source #1 Input parameter. you can even use the Key input as a published input value. then you can duplicate this macro and change band values.
You have to edit it in QTZ first.so 13 bands equalizer can works into modul8?to select the band you want to bind to your equalizer select go to tu vu macro then find the blue box "audio inpu" then link the spectrum output to the structure Key member module then in this module as the Key input parameter enter "band_0" for band 0 this audio spectrum values goes from band_0 to band_12.
you just tried it?
thanks
