how to create a round mask?
  • brain
    by brain » Sun Oct 28, 2007 3:17 pm
    hi there,
    this sounds so simple, but i have not yet found the best way to create a round mask. yes, i have created a huge black PNG whith a round hole, and this works.
    but it would be much more convinient to have a circle black shape with transparency around it; and invert this mask.
    any ideas on that? how to invert the alpha channel on a single layer?
  • mowgli_uk
    by mowgli_uk » Mon Oct 29, 2007 5:47 pm
    what's wrong with the png you've created if it does the job?
    you can't invert non-existent pixels.
  • brain
    by brain » Mon Oct 29, 2007 6:57 pm
    if i use a big solid PNG with a transparent hole, there is a limitatiion to scaling and rotation, because at some point the edges of the PNG will be visible.
    so it would be more clever to have just a circle shape with transparent suroundings just show whats inside.
  • mowgli_uk
    by mowgli_uk » Mon Oct 29, 2007 7:08 pm
    just make the png with a bigger space around it, being a still it won't take much cpu.
    alternatively make a png or jpg with black and white rather than using an alpha channel and then use the luma key accordingly
  • moonbase
    by moonbase » Mon Oct 29, 2007 10:02 pm
    Agree with mowgli, make it really big, keep experimenting to find a size that suits.
    I made a round mask for a cd launch show which took place in a cinema near me and used it
    as a spotlight for the 'tween number announcements, see here:
    http://moongold.me.uk/gig/
    first clip, about 35 secs in.
    Worked a treat. It was 5000 x 3000 if I remember and very small in kb, can't find it
    at the mo but a few 100 kb no more. Colour change on auto, movement, great.
