midi joystick
  • bal
    midi joystick
    by bal » Mon Oct 29, 2007 3:47 am
    can we map a usb joystick in modul8?
    by sigmasix » Mon Oct 29, 2007 10:19 am
    yes. there is a small utility that convert the usb signal to midi called junXion
    you can find it here http://www.steim.org
  • Lupin
    by Lupin » Mon Oct 29, 2007 10:42 am
    but first you have to make your gamepad /joystick recognized by mac OSX before you can bind midi into junxion. junxion only routes midi signal to HID .to connect your joystick to your mac use Gamepad companion
    http://www.carvware.com/gamepadcompanion.html
    zoophar
    by zoophar » Mon Aug 11, 2008 12:22 pm
    Hello Bal
    I've tested some application for midi joysticks and gamepads…
    finally, i used usb overdrive (or gamepad companion)and then
    transform the signal with pure-data (instead of junxion)
    using the hid object (they say it is beta but it work good) to transform the signal into a midi signal
    it takes some time but i saw that junxion doesn't send isolable data
    hope it is helpfull
