hi,
it is possible make the sound input in modul8 by an external source line in?
thanks
Lupin wrote:then use soundFlower sound router to route sound from itunes to M8, if you haven't lost your ipod link cable hehe
mowgli_uk wrote:ok, I do this all the time and trust me, it works. Follow the instructions in this order:
1. connect your sound to your mac using the line port
2. open system preferences/sound/input -select line in and tweak the volume, you should see the input bouncing up and down. If you don't there is a problem with your mac's line input or with your sound source.
3. open modul8 and tweak the sound input knob, it is useful to have the soundviewer module open to see the level of the incoming signal.
That's it.
