jitter (of cycling74) to Module8 , a kind of video pipe ?
  • zoomak
    by zoomak » Wed Oct 31, 2007 9:07 am
    Hello all ,
    is there a way to have some streaming video from Jitter to Module8 internaly.
    I mean I have some generative processes in jitter and I woul'd like to mix that with other media in Module8 .... on the same Mac ! Is there a sort of video pipe or network or smthg like this betwin two apps on the same machine ? ..... before I have to buy a Krossfour and mix all in the analog world.
    thks
    zoomak
  • bighairmusic
    by bighairmusic » Thu Dec 27, 2007 4:32 pm
    yes it would be nice to have virtual 'streaming' of video within a mac similar to how you have it with audio, soundflower/jack/net send and receive etc... could OSC do anything like this?
  • technomorph
    by technomorph » Thu Dec 27, 2007 10:28 pm
    Cycling 74 have teamed with Ableton on the video front....and you'll be seeing more video stuff in Ableton, so I doubt you'll be seeing this type of thing between any of the projects.
  • bighairmusic
    by bighairmusic » Wed Jan 02, 2008 10:50 pm
    i'm not sure they're doing anything especially (with Cycling74) on the video front specifically, rather than audio/midi/patching, although i'd love it if they did..
  • gagarine
    by gagarine » Mon Nov 03, 2008 2:17 am
    I very intersting too! And is better if we can communicate in two way...
    Perhaps we can do like that:
    jitter -> videout -> firewire out -> firewire in -> modul8
    So the firewire cable go out and in in the same computer... not sur if it work...
    Me i need also get the output of modul8 IN puredata or Max...
    EDIT:
    I'm sure it can be done with quartzcompozer http://flow.la-va.org/?p=166 no?
  • strimbob
    by strimbob » Sat Nov 15, 2008 9:58 pm
    hi all,
    i have just got modul8 to work in side jitter, with jitter object jit.desktop, or does anyone known of a better way?
    thanks ben
  • gagarine
    by gagarine » Tue Nov 18, 2008 11:07 pm
    The best way i found is use this chaine
    DVI -> [DVI TO VIDEO] -> camera video in -> DV (Firewire or USB) -> PC
    I use this convertisor: http://store.apple.com/us/product/M9267G/A
    I use only the camera to have an analog video input for my mac...
    After in Max you can use the objet to grab a camera signal...
    Good luck.
