maximum resolution of text module?
  • brain
    by brain » Mon Nov 05, 2007 9:08 pm
    dear all,
    is there a way to get larger text? the resolution control of the text module is very limited, and just resizing a layer gives bad type quality. it would be sooo great if HUGE text was possible...
    thanks for tips!
  • Lupin
    by Lupin » Tue Nov 06, 2007 8:12 pm
    yup it's possible ,open the module Editor and click on the resolution pot then change the number inside the max field to the max size you want. you can also prevent from displaying a too small size by tweaking up the Minumum value of this Pot.
    i tried with a max value of 2000, and works fine.
  • brain
    by brain » Tue Nov 06, 2007 9:42 pm
    wow! thanks!
    i never used the editor before because i did not want to mess things up :)
  • Lupin
    by Lupin » Tue Nov 06, 2007 9:51 pm
    if you don't want to messup things jsut duplicate the module you want to edit then it's safe to experiement everything you want :)
    by the way it is one of the best way to learn how to make modules by editing them.
Users browsing this forum: Baidu [Spider] and 29 guests
