Mini manual with doubts of modul8
  • davidestyle
    by davidestyle » Wed Nov 07, 2007 12:39 pm
    your can say as I set the output to the monitor in extended me make a full screen ...
    As this makes me default on my screen, and even drag to widespread gives me the full screen in the main.
    And you can say I like work you to get an idea of the philosophy of modul8? ?
    I see it as work after effects but live ... create your compositions in each of the 8 layers you have and mixing with 8 who have below with the crossfader.
    But from what I have seen has no means of fusion between group A and B.
    And to finish, you shall preparais first session with clips modified, mixed ... And what save? And if so then are you charging groups? ?
    Greetings! ! ! Thanks! ! ! sorry for my english!! :P
    VjKg
    by VjKg » Thu Nov 08, 2007 1:12 am
    Don't understand much of what was said but I think for fusion of A and B you just need to deselect the fading and scaling option. Maybe I am wrong but you should try the Spanish forum. Also it seems you need to change your advanced output option to get on your secondary monitor.
