can not sync to audio + problems with filter(layer)
  • treas
    by treas » Thu Nov 08, 2007 1:51 am
    i´m new to modul8, it´s a really nice software but i have two problems:
    1.
    the bpm(global) module doesn´t let me sync the prog to the audio in.
    i´ve got an audio signal (i see this with the sound viewer tool
    and the "auto-move-by-sound-in" for example works too).
    sync to midi works fine, also the tap is ok.
    2.
    the filter(layer) module only saves the parameters from the first effect.
    if i open a project, i have the 3 other fx too, but all parameters are set to zero.
    any suggestions?
  • Lupin
    by Lupin » Thu Nov 08, 2007 11:41 am
    1.
    if you want to bind the audio in with Bpm, BPM (global ) is not theright module to use. BPM(global) only sets the BPM speed . to bind audio in Pot to the bpm please use the BPM M-router (master) and use the "pick" button.
    2.
    it's is normal, the module son't saves preferences, you gotta ask someone to edit the module or try to edit yourself. it's written in python. if you read the manual you'll find out how to save prefs. it's not a big deal but you gotta find the right dict to save.
    cheers
  • treas
    by treas » Thu Nov 08, 2007 12:32 pm
    thanx for answering!
    but for 1. - my ask was not accurate probably.
    i meant that the bpm(global) doesn´t recognize the speed,
    if i press -sync- nothing changes. but it recognizes a midi clock signal.
  • sonicslice
    by sonicslice » Thu Nov 08, 2007 11:35 pm
    The 'sync' on the module is to sync it to MIDI not audio, it doesn't do sync to audio.
  • treas
    by treas » Fri Nov 09, 2007 1:11 pm
    ah, ok.
    then I understood wrongly the documentation.
    merci
