Evaluating VJ packages, need help with multiple live sources
  • tinisi
    by tinisi » Tue Nov 20, 2007 4:13 am
    Modul8 Support,
    I love your program. I want to be able to use one USB web cam and one FireWire webcam, at the same time - one on the A channel, one on the B and mix them. I have two cameras to test with, and I can get either one (one at a time) attached to the "sp" tab's Live Video Capture source, so I am sure the drives are OK. However, since there is only one "sp" tab with a single Video Capture source, how can I assign two different cameras at the same time?
    I know Modul8 is very extensible, so I *hope* it is possible somehow. I did try assigning first the USB cam to a layer, then using preferences to switch to the FW cam, and assign that to a different layer. When I do that, as soon as the Vide Capture source is clicked on the second layer, the first one changes to some other instrument.
    I also realize there is a limitation on having two DV streams on a single FireWire bus, that is why all I am hoping for is one USB and one FW.
    Note, I *can* get this to work in Arkaos, so I am pretty sure my computer and the drivers for the cams are alright.
    Thanks much! I hope to be a future garageCUBE customer!
    Jason
