Ghosting Effect
  • vjtscho
    Ghosting Effect
    by vjtscho » Tue Nov 27, 2007 12:38 am
    Hi all
    I need to do a ghosting effect on a live video input. I found a nice quartz composer effect. Now my problem. I also have to feed in other live video. So when i import the quartz composition with the dfg1394 as input source i can't use the dfg1394 in module8 as video input.
    Is it possible that module8 and the qc can access the same video input at same time?
    If not, i should have a ghost effect in the filter module. Is it possible to import a quartz composition just as a filter in modul8?
    Or do you know a good ghost effect for modul8 for free?
    Thanks for your help.
    Greez
    vjtscho
  • JJHP3
    by JJHP3 » Tue Nov 27, 2007 8:13 pm
    Trace??
    - JP
  • vjtscho
    by vjtscho » Tue Nov 27, 2007 9:16 pm
    ghosting!
    its like a delay on some recent frames that continously fade out then. So moved object are on screen several times but with different opacity.
    vjtscho
    Like ghosting effekt on Adobe Premiere
  • vjtscho
    by vjtscho » Tue Nov 27, 2007 9:48 pm
    Just found the trace button!
    Great. But the trace doesn't apply to my live input over dfg1394!!!
    Any solution?
    by sigmasix » Tue Nov 27, 2007 11:11 pm
    use chromakey to have your input a bit transparent on the background to make trace effect working
  • vjtscho
    by vjtscho » Wed Nov 28, 2007 1:09 am
    Thanks a lot!
    Works perfcetly!
    vjtscho
