bcf 2000 mapping layout?
  • Buchhodt
    by Buchhodt » Sat Dec 01, 2007 11:17 pm
    Hi there..
    I'm pretty new to the VJ enviroment. I have trying M8 for about a month, and today I got my bcf 2000 midi controller. And it seems very nice so fare. But as it is my first midi controller. So I have some setup problems. Witch I has hoping you would help me with.
    Do I have to du the mapping all by my self? or is there a presset layout or something? If I have to map it myself, do you have some tips for me to get the correct layout? Have have you guys set yours up?
    Jaime / www.starloops.net
    by Jaime / www.starloops.net » Sat Dec 01, 2007 11:33 pm
    there is a beta modul from Boris to use with the BCF.
    I think you can get it with on the module internet lib.
    Jaime
    Starloops Manager
    http://www.starloops.net
  • Buchhodt
    by Buchhodt » Sun Dec 02, 2007 1:12 am
    Sounds great..
    But I can't seem to find it in the online libary. Do you know hvad the name of it is??
    by boris » Sun Dec 02, 2007 6:09 pm
    BCF 2000 BETA
    click on "name" and it is the first one.
  • Chris_lim
    by Chris_lim » Fri Dec 14, 2007 8:25 pm
    Sorry to ask where can I find the bcf 2000 mapping layout for modul8
    New to BCF2000
    sorry and thanks
  • mowgli_uk
    by mowgli_uk » Mon Dec 17, 2007 3:07 pm
    Chris_lim wrote:Sorry to ask where can I find the bcf 2000 mapping layout for modul8
    New to BCF2000
    sorry and thanks
    there isn't one, you map it yourself.
    Vincent-Pimousse
    bug module BCF2000
    by Vincent-Pimousse » Tue Jan 08, 2008 1:27 pm
    (there is french version here)
    :idea: I believe I found a bug of the module BCF2000 when connected to the module BPM router ( LAYER). When I animate a parameter such as the transparency or the color of a layer, it has the effect of making move the corresponding fader when the layer in question is selected with the console. (To there everything is well is it is rather fun to see faders to move in rhythm). When I go to focus on the console the fader continues its movement, normal the same layer is still activate.
    The bug: when I activate another layer with the mouse (and the bcf is still in focus mode), the fader continues its alternate movement instead of stoping in the good position. I do not have to dare to animate the same parameter on different layers but that has to not be attractive to see :P
