Module8 and Aja io
    Jaime / www.starloops.net
    Module8 and Aja io
    by Jaime / www.starloops.net » Wed Dec 05, 2007 4:05 pm
    I tested this morning the Aja io with my macbook pro on leopard..
    Works !
    The latency is very low :)
    HD sdi is perfect !!
    You have to see HD real time capture in m8 it's incredible !
    Well the only major problem is the Aja io price..
    So I order finaly the Black magic deck link HD extrem and I'll try it with a magma chassi.
    Give you more new after received it
    Jaime
    Starloops Manager
    http://www.starloops.net
  • bratch
    by bratch » Wed Dec 05, 2007 5:16 pm
    I've tried with a blackmagic HD extrem on MAC PRO,low delay but not low enough to work with someone speaking on a mic, the lip sync is not good enough( it depends on what you can accept for your gig). Plus, the more layer you have and/or the bigger your medias are, the more delay you'll have on live input...
