BCR2000 Global midi setting options
    VjKg
    by VjKg » Thu Dec 13, 2007 8:49 am
    After having debated for over a year I finally bought the BCR-2000. After using the search command to no end I have three main questions left for the Forum. To anybody who is looking for which one to buy "DON'T POST, SEARCH".
    Can I set the top row of push/turn rotary encoder groups (8/8 actual-32/32 virtual) to a Global setting over all of the presets (P1-P32)?
    How can I change each preset group to assure a different channel for each knob within each preset group? I have found some of the Audio Program Factory presets share midi channels across the preset groups.
    I want the presets buttons to not effect the encoder groups, so I can have more control.
    Finally, Can Modul8 move the LED encoder light when changes are made via software or automation?
    Before you all explode, I know this is not a Behringer Forum. I also know I can change each knob/button manually. I want to fun easy answer like "The BC-Edit_02beta3 program does it very well." or "Hold this button, then when it blinks, press this button until you see EX5". The 1 by 1 method seems so 1989.
    I have some presets already and I am working on an overlay. My desire is to make a simple easy to remember setup that other visualists can play with during shows. I gotta take a break sometime.
  • DJSare
    by DJSare » Thu Dec 13, 2007 10:27 am
    Hello
    To change the LED you are send midi out to the BCR-2000 control.
    here are a new Modul for BCF-2000: http://www.garagecube.com/forum/viewtopic.php?t=1940
    You can edit the script for you style. I have selfe
    by 2 BCR-2000 control, but i patch with MAX MSP and then
    to Modul8.
    A litle more info scripting midi: -> the manual
    http://www.garagecube.com/forum/viewtopic.php?t=217 or
    http://www.garagecube.com/forum/viewtop ... highlight=
    Good times
    SARE :P
