Perspective Transform w/ 6 Points?
  • SUN
    by SUN » Sun Dec 23, 2007 5:44 am
    Can anyone tell me if there is filter that supports the distortion of more then four corners of the projection?
    I know "(CI) perspective transform" lets you distort 4 corners.. though I'd like to map one projection over the corner of two walls, keeping the perspective inline and even.
    Thanks in advance..
    deepvisual
    by deepvisual » Mon Jun 02, 2008 4:52 pm
    use two layers with crop filters and PT.
    you can trigger them both at the same time with the layer set?? modul
  • MysterE
    by MysterE » Tue Jan 06, 2009 8:23 am
    I cannot seem to locate this efffect or module. I have looked all over.
