Freeframe
  • mr_coops
    Freeframe
    by mr_coops » Fri Dec 28, 2007 10:24 pm
    Hi guys,
    I have downloaded some freeframe plugins. but am experiening some difficulty.
    The 'wave' freeframe doesn't seem to work with modul8 has anyone else experienced this. When applied to a clip the clip just goes blank. I know thee freeframe is sound as it works in other applications fine.
    Any suggestions would be welcome.
    Also is there a way to convert windows freeframes to work in osx?
    by sigmasix » Sat Dec 29, 2007 2:34 pm
    have you searched the forum? there are some threads about it and lists of freeframes plugins that are not compatible with modul8
  • mr_coops
    by mr_coops » Sat Dec 29, 2007 2:55 pm
    well Sigma6,
    I've had a search and this thread sounds like the wcve efect should work
    http://www.garagecube.com/forum/viewtop ... light=wave as does this one
    I don't know if it's due to the clips I'm using or anything. I've tried using it in Arkaos on the same clips and all seems fine :? It's a shame as I do really like this effect...
