" alpha channel (transparency) "
  • BASS:FRQ
    by BASS:FRQ » Sat Dec 29, 2007 2:59 am
    I was wondering if the "alpha channel (transparency)" would work from particleillusion? It says it can make a transparent layer, so it would be nice to make real fast particle frames and load them up.
    Anyone know more on this?
    Thanks for any help, sorry I am noob. :(
    Since particleIllusion is a standalone application, you can use it with any video editing or compositing software. Bring your movies or image sequences into particleIllusion, add the particle effects you want, then save the output movie or image sequence. You can also save just the particles with an alpha channel (transparency) so the rendered output can be loaded back into your compositing software.
    http://www.wondertouch.com/
    deepvisual
    by deepvisual » Sat Dec 29, 2007 1:53 pm
    just depends what codec you use when you export from PI.
  • bratch
    by bratch » Sat Dec 29, 2007 2:36 pm
    PNG codec and Animation+ codec both work and keep the alpha channel
    deepvisual
    by deepvisual » Sun Dec 30, 2007 7:15 am
    remember.
    PI is a pc prog, you'll need to make your clips .movs and mac friendly.
    set your output to millions of colours +
  • BASS:FRQ
    by BASS:FRQ » Sun Dec 30, 2007 7:50 am
    remember.
    Code: Select all
    system requirements Windows: Win 98/NT 4/2000/XP 1.8 GHz CPU 256 MB RAM 1024x768 64MB video card with OpenGL support Macintosh: Mac OS X 10.2.8 or newer 1.0 GHz G4 CPU 256 MB RAM 1024x768 resolution
    And thanks everyone for the help.
  • VJnutcracker
    by VJnutcracker » Sun Dec 30, 2007 5:00 pm
    Particle Illusion now out for macs, i prefer Motion tho
    http://macvideopro.digitalmedianet.com/ ... p?id=35445
