first steps on BPM
  • lu
    first steps on BPM
    by lu » Tue Jan 15, 2008 9:47 pm
    I just would like to known how to get beats sync with the loop images. Im using the regular input audio on my powerbook. Theres a tip to put the beats sync with the images automaticle?
    Thanks
    LUCIANO
  • Le Mékanôme
    by Le Mékanôme » Wed May 28, 2008 11:30 pm
    If you use the module BPM layer router (in use with the module BPM Global), you can sync what you want with a definite BPM (or you can sync it with an outside bpm signal, via network i.e.)
    If you want to sync the speed of your media, pick theLayer Movie Shuttle (one of the rotary controller under the speed). Divide the BPM if the movie's too long.
    Hope it will help you
    L.
