miniMAD Light 3.6.1: No output using USB-DMX devices
    by Pierre Guilluy » Thu Nov 15, 2018 6:14 pm
    We've detected a problem that prevents miniMAD Light 3.6.1 from sending DMX using USB-DMX devices like ShowJockey, GarageCube or Enttec interfaces.
    This problem will be fixed in MadMapper 3.6.2.
    In the meantime, you can use MadMapper 3.3.3 (available on Yourspace) to export your DMX sequences to miniMAD.
    Prior to exporting, in order to force MadMapper to downgrade your miniMAD, you will have to trash the app/ folder that's on the SD-card, or flash the SD-card following the procedure that's on the miniMAD user-guide.
    We're sorry for the inconvenience.
    The garageCube team
