Momentary vutton
  • Vjstillet
    Momentary vutton
    by Vjstillet » Sat Jan 26, 2008 10:01 pm
    Excuse me for the bad english...
    This is my problem....i would to build a modul with a momentary button for the command hidden layer (When the button is activated the movie is visible, when i leave the hand from button the movie is hidden)...but i don't figure how build this type of button... :cry:
    by sigmasix » Sat Jan 26, 2008 10:10 pm
    check out the module I made (s6) Cut (all) in the online librairy, it does what you whant, you just have to modify the keyword.
    Read also the documentation, it's well explained
  • Vjstillet
    by Vjstillet » Sun Jan 27, 2008 4:46 am
    thanks sigma, but this module isn't that i search...i try to change the keyword but nothing...
    i try to build the "hidden" module, and it operate very well in toggle...when i try to change it in momentary the modul don't work...why?
    I have another idea...the same method is applicable to layer alpha too...but i trust that i have the same problems :oops:
