Multiprojection problems on a new mac pro 2008
  • RickRobiN
    by RickRobiN » Thu Jan 31, 2008 8:54 pm
    Hey
    Testing a mac pro 2.8 8core. with 4x Ati Radeon HD 2600. with the dvi>composite adaptor.
    The problem is that in the preview panel nothing happens with all the photo-jpg or dvcpro HD quicktimes. only h264 works but .stuttering a lot.
    Still the video works on all the outputs in al the codecs without any problems
    (only in the fullscreen mode. if not a white image is shown, same as in the preview panel)
    It happens with 2.5.4 and the Beta.2.5.5.
    Is this a quicktime 7.3 problem or is it the new octo mac pro hardware?
    cheers RR
  • bratch
    by bratch » Fri Feb 01, 2008 12:10 am
    it looks like it's quicktime ! when you play a photoJpeg file, if i understand what you say, it should be white i guess. Then, try to activate a pix FX as contrast or light or whatever pix FX, then your clip should appear, but slowed down because of the effect. If this is what happens for you, then, it's because of QT ! Up to now, for multiprojection, only quicktime 7.1.3 works fine with M8 V2.5.4 (and of course with tiger)
    by sigmasix » Fri Feb 01, 2008 12:31 am
    I don't know what's happenig to the computer world these days, many software are downgrading their options in their updates.... leopard is full of bugs that didn't exist in tiger, quicktime doesn't play flash files anymore... and because of that, many sowftware that are based on quicktime have problems right now, even the biggest like after effects cs3 that cannot render more thant 10 minutes because of the latest version of quicktime :evil:
  • RickRobiN
    by RickRobiN » Fri Feb 01, 2008 1:34 am
    So if I install tiger on a seperate harddisk, I will be lucky with M8 V2.5.5 Beta
    Mac OS 10.4.9 QT 7.1/7.2/7.3? with the ATi HD 2600 in theory?
    By the way, modul8 only use one of the 8 cores. makes it sense to use h264 because there is enough processor overhead power for h264 to decode so I can keep the datarate low and play more clips at higher resolution?
    one last question, nothing to do with this subject, why can't I move my clips not anymore in the x and y axis,?
    and yes, apple is not prosumer anymore :( All the fancy quicktime updates for itunes etc. are disturbing, also not sure about leopard advantages so far compared with tiger.
    btw Thanks for the answers!
    cheers RR
  • bratch
    by bratch » Fri Feb 01, 2008 9:22 am
    The only thing i know is that only QT 7.1.3 (not 7.2 or 7.3) worked with M8 v2.5.4 for multiprojection on my macpro 2.66gh. With the others version of QT, i had pbs of white medias as you described. And i'm very disapointed to hear that it's still the same pb with a new mac pro and the last graphic cards and leopard. I was hoping that the pb would be solved but no, not yet.
  • dodeskaden
    by dodeskaden » Wed Feb 06, 2008 7:44 pm
    hello,
    Where can you find quicktime 7.1.3,
    I just bought a mac pro with QT 7.2 and I am testing modul8 demo for multi screen and I got thewhite screen problem
    Thanks
  • RickRobiN
    by RickRobiN » Thu Feb 07, 2008 3:33 am
    Hey Dode.
    The only solution to get rid of the white frame is to re-enncode everything to h264.
    Installing tiger& 7.1.3 on the new mac pro disables quartz btw. (It's also not possible normally on a new mac pro to install tiger)
    I am not sure to download the new update of quicktime released today.
    But maybe maybe this is the solution....... You never know
    I will post the answers soon
    cheers
    RR
  • RickRobiN
    by RickRobiN » Thu Feb 07, 2008 4:59 am
    :D photojpg is working again in quicktime 7.4.1
    Both modul8 2.5.4 and 2.5.5
    Still some performance drops in the preview panel, but not in the output.
    cheers RR
  • dodeskaden
    by dodeskaden » Fri Feb 08, 2008 5:55 pm
    I tried QT 7.4.1, with a mac pro. M8 2.5.4
    Still white square with ptoo jpg compression ,and also with tiger 10.4.11 and QT 7.1.3?
    White square dissapear only with QT7.1.3 and os 10.4.8. but it seem to be much more solw,
  • NdR
    by NdR » Sat Feb 09, 2008 2:16 pm
    help me!!!
    but is possible to use new macpro 8 core whit 4 ati card (8 output) for a good multiprojection????
    i have purchsed new machine (tomorrow here!)
    the last quicktime upgrade resolve all the problem?
  • RickRobiN
    by RickRobiN » Mon Feb 11, 2008 6:43 am
    Just keep it with h264. Forget jpg and you will be fine.
    (and test test test test :)
    And use 2.5.5.
    (Got the feeling that h264 makes the clips really small and it easier for modul8 to handle, it ' s all about datarate now. So it's good to keep it as low as possible or am I wrong?)
  • RickRobiN
    by RickRobiN » Mon Feb 11, 2008 9:47 am
    modul8 and quicktime crashes on loading a lot of h264 files.
    Not on my mac book pro.
    Quite strange...............
    Anyway, loading not the whole libary is a work around. Hope there will be no other strange things will happening during the gig..
    (white screen of death... report If you have it please....)
    modul8 2.5.5 quicktime 7.4.2 mac pro 2.8
    by sigmasix » Mon Feb 11, 2008 10:19 am
    why did you write your crashlog in here?!? it's too big and no one cares about it... you should send it to support :at: garagecube :dot: com in a text file...
  • RickRobiN
    by RickRobiN » Mon Feb 11, 2008 10:33 am
    no prob. will delete it and send it directly to garagecube
  • RickRobiN
    by RickRobiN » Mon Feb 11, 2008 12:56 pm
    problem solved, with preloading @ 0.mb
    I am ready for my first 2k gig :)
Users browsing this forum: No registered users and 76 guests
