quartz composer problem
  • suicase
    by suicase » Sat Feb 09, 2008 7:42 pm
    hi, i've got a 2,2 MacBook pro with 2gb of ram and leopard, bought on december. i've got the last version of quicktime (7.4.1 (14)) and modul8 last version (2.5.4). the problem is that i can't use quartz compositions, even if saved in a Quicktime mov as tried by others. modul8 just can't use audio in line, even if the sound is used by automove and other as a source. I don't know how to do it, please help!
    zoophar
    by zoophar » Tue Jun 03, 2008 2:15 pm
    i don't know if i understood but:
    sound input in quartz composer is independant.
    even it is imported in m8, .qtz sound input files only works with the "General Mac sound input" (the one you see in system preferences...)
    in M8, turning the Volume knob won't change anything...
    you have to change it in the System Prefs'
    or else, increase the intensity of the input (with "Math") in .qtz...
  • bAjA
    by bAjA » Wed Jun 04, 2008 11:58 am
    this safe audio input by kineme might help.... also check out there safe video and safe midi...
    http://kineme.net/QuartzComposerPatches ... oInput/0.1
    bAjA
