Hi All,
It's been a while since I looked for this function...
Is there any Module that will allow the loading of obj models and applying a texture to them?
Modul8 is still the best!!
Cheers,
I know this post from SARE is very old but if you can control the QC comp with OSC when loaded inside modul8, would you mind charing that module? My experience is that all QC comps are cut of from communication with over OSC and Midi when loaded in Modul8.Hello Modul8 Freaks
I have check this way and good news, this work![]()
To better work flow you can use the OSC-Modul in Modul8 to make a new
little Modul for direkt pipe for phat/x/y/z.... to the Quartz-Composer-Patch.
Nice day and good times
SARE
Orion, since you're a big fan of Syphon, if I were you I'd look in to loading the 3D model in QC and sending it over Syphon to Modul8. You can hook up MIDI controls to all the 3D patch variables in QC. You can then control your 3D object while you're working in Modul8. Just see to that you're not overlapping any other Midi messages you're already using.Well I can control the rotation using rewind and fast forward inside modul8, duh. Still wondering about other controls live however, say wireframe toggling, etc.
It sounds like a great way to enhance Modul8. Can't wait to have fun with it!Hi picel8
I have not testet in Leoopard, use OBJ Loader for Quartz Composer 3.0.
Info: http://www.vidvox.com/phpBB2/viewtopic.php?t=2333
You can open a QC-Patch in Quicktime and save as .mov
(Modul8 nead this to open it)
Use midiinput inside the QC-Patch to change y/x/z and more.
Info: http://www.vidvox.com/phpBB2/viewtopic.php?t=2323time calculator
Have fun
DJ Sare
