(WTA) how to change color interface modul8??? (PIC INSIDE)
  • Lando
    by Lando » Mon Feb 18, 2008 3:25 pm
    can anyone tell me how to change to interface color from blue to dark/black like this one?
    this take from flickr
    http://www.flickr.com/photos/cart1/2078887746/
    thanx.
    really need to know. :)
    by sigmasix » Mon Feb 18, 2008 7:53 pm
    this is a special version of modul8 made for la demeure du chaos, a group of artists near lyon in france. the version is more than just couloured different, all the interface is chaotic. Maybe Lupin can tell you more if he read this thread, he's the one working with it ;)
    But you can still change color of elements of the interface by opening the package of the application (right click on the modul8 icon > open package) then you have all the images files used by modul8 wich you can modify a bit (you should work on a copy of the application in case you destroy everything) but not every elements of the interface can be changed... good luck (and this is not something done fo all the versions,if you update modul8 you will need to do it again...)
    I don't know if the garageCube team like it a lot but this is possible technically.
  • Lando
    by Lando » Mon Feb 18, 2008 8:23 pm
    wow. thanx for the info.
    I'll give it a try...
    THANX!!
  • Lupin
    by Lupin » Mon Feb 18, 2008 9:41 pm
    the DDC version is a special edition.
    as Sigma said, you can change media files. they are located inside a hidden folder inside the app package. though you can change the global aspect the main interface, some sliders, typo, and backgrounds still remains as the basic skin.
    The final release with seamless graphic integration, chaotic jittered interface was made by GarageCube. please notice that this version is not available for retail it's part of the video installation we did for the abode of chaos and garagecube is not responsible for disfunctions of the software in case of you tweak graphics.
    if you want a full skinning feature in a future release send a wishlist message to garagecube ;)
    and i agree with sigma, i'm not sure garagecube will really like this sort of Tunning feature ;) .
  • Lando
    by Lando » Tue Feb 19, 2008 10:35 am
    rather than I change it manually...
    i think i rather add it to the wishlist..
    thanx guys!
