Fixing live input Interlaced issues
  • gilime
    by gilime » Wed Feb 20, 2008 8:30 am
    I am using the demo software to see if this software is going to work for us or not and i am having some issues with the footage looking very liney on movement. It is obviously a interlacing issue but i am unable to get it to go away no matter what setup i use.
    I am running a decklink card with an sdi input and using 3 vga outputs.
  • Lupin
    by Lupin » Wed Feb 20, 2008 12:18 pm
    modul8 does not interlace video signal. but if you use interlaced footage of course M8 will display it. since there's no interlacing feature in Modul8 you can't find this pref inside modul8. maybe the only way to get rid off this interlacing issue is to look at video input compression preferences inside the preference pane inside modul8.
    good luck
