Trigger short video samples over a longer movie
  • medesign
    by medesign » Fri Feb 22, 2008 6:54 pm
    I have a question about triggering a short video sample over a longer movie.
    What im trying to do is trigger short videos with a drum pad while a longer 4 - 6 minute video runs underneath.
    I want the short videos to trigger once and then return to the longer video underneath, and i dont want the long movie to repeat again from the start just continue playing.
    How can i do this?
    Thank you,
    Matt
    deepvisual
    by deepvisual » Sun Mar 02, 2008 11:50 am
    easiest way is to just x-fade between A and B.
  • cycloptic
    by cycloptic » Wed Mar 05, 2008 9:15 pm
    a better way would be to use the media keyboard module, assign your drum pads to the clips you want to use, and highlight the "trigger" button.
    this will only play/show the clip for as long as you hold the button down, with the other video still playing in a layer underneath
