V2.5.4 Layer/Media Issue
  • Movement
    by Movement » Sat Feb 23, 2008 1:12 pm
    Whenever I open up a saved project, every layer that is active opens as the clip from Media Set 1, Media ID:1. This also happens when I duplicate a layer. Instead of a copy of the layer, the new layer is the clip in Media ID:1.
    Can anyone suggest a solution plesae?
  • Movement
    by Movement » Sat Feb 23, 2008 1:49 pm
    Just read that someone else had this problem and it was to do with the 'slideshow' module. I'm not using that module so.....er....anything else?
    by sigmasix » Sat Feb 23, 2008 2:58 pm
    As I said in the post you mentioned, it can come from a module, try to "pause" every modules to see if it comes from any of your active modules
  • koerk
    duplicate layer bug
    by koerk » Thu Aug 14, 2008 1:34 pm
    mister movement!
    this is bruno tait, nice to "see" you here :)
    did you solved the problem with the swapping Media when duplicate a layer ?
    because since last update (2.5.6) i got the same problem.
    also i paused every open module ... its the same.
    in case somebody figure it out... please let me know.
    regards,
    koerk (bruno-tait)
