DELETE!
    cheveria
    DELETE!
    by cheveria » Sun Feb 24, 2008 12:03 pm
    Im sure you have answered this question before.
    HOW DO I DELETE MULTIPLE FILES AT THE SAME TIME?
    DOES M8 SUPPORT THAT?
    Anybody?
    Valparaiiso
    by Valparaiiso » Sun Feb 24, 2008 8:02 pm
    No, you can't. M8 doesn't support that.
    Voilà. :cry:
    cheveria
    by cheveria » Thu Feb 28, 2008 6:00 pm
    I THINK MODUL8 TEAM SHOULD WORK ON THAT,
    Its very bad to delete them one by one, takes too much time.
    Also the decks soon as i fill them out i start gettin' red dots.
    And my clips are Low res too 320x240
    And i do have an OK machine, MACBOOK PRO 2 GB RAM, 7200 rpm.
  • Lupin
    by Lupin » Thu Feb 28, 2008 6:06 pm
    YES YOU CAN with the beta 2.5.5
    but thanks to a module since you can load dynamically clips into mediaset.
    cheveria
    by cheveria » Thu Feb 28, 2008 9:23 pm
    R U SERIOUS LUPIN?
    You can do that NOW!!!
    where do i upgrade? sign me up...
    :) thanxxx
  • Lupin
    by Lupin » Thu Feb 28, 2008 10:34 pm
    search for the topic about the beta 2.5.5 i don't remember where it is . and then ask garagecube to get it . don't forget that it is a beta version
  • videomasta
    by videomasta » Fri Mar 07, 2008 10:33 pm
    after 1 hour trial and error:
    modul8.setValue('direct_media_change',[theMediaPos, u""],0)
    deletes a media at position: theMediaPos
    i could not find a documentation :-(
    cheveria
    by cheveria » Sun Apr 13, 2008 11:09 pm
    Lupin...
    i tryed the 2.5.5 version.. but i cant DELETE multiple files.
  • Lupin
    by Lupin » Mon Apr 14, 2008 12:12 am
    Don't search, and look at modul8 library, i jsut upload the (vs) CLEAR Mediaset (all) module to delete mediaset or all media at once
    cheveria
    by cheveria » Mon Apr 14, 2008 11:35 am
    lupin,
    thanx for the reply.
    but sorry to sound such an amateur but i dont get what you are tryin to say... do you have a path how should i look for that thing.?
    thanx.
  • Lupin
    by Lupin » Mon Apr 14, 2008 12:02 pm
    go to the "Modules" drop down menu then choose "Online Library"
    then go to the Public Library and search for (vs) CLEAR Mediaset (all) module
    cheveria
    by cheveria » Mon Apr 14, 2008 6:58 pm
    Got it.
    it works, thanx a lot Lupin.
