vj set recorder?
    cheveria
    vj set recorder?
    by cheveria » Mon Feb 25, 2008 1:20 pm
    Im looking to record my VJ sets, if anybody can help me, it will make my life easier.
    I dont want to spend a lot of money, is there a device that while im Vj-in LIVE i can record the video and the audio at the same time?
    Please HELP?
  • technomorph
    by technomorph » Mon Feb 25, 2008 9:50 pm
    Get a Sony Dig8 deck or miniDV deck.
    A DVD recorder is not a good option as the MPEG2 compression is set and doesn't always
    work well.
    wygiwys
    by wygiwys » Sat Mar 08, 2008 11:49 am
    The Pinnacle video transfer Can record audio and video, and encode it straight away to your ipod or hd (only windows formatted hd's). Maybe that can be useful for you...
    What You Get Is What You See
    WYGIWYS.tv
    cheveria
    by cheveria » Sat Mar 08, 2008 3:57 pm
    thanx, wyglwys
    But, thats not it eithe,r it doesnt record the outputs ,
    its just a simple video transfer device.
    I cant belive somebody hasnt come out with this thing yet.
    wygiwys
    by wygiwys » Sun Mar 09, 2008 1:45 am
    It converts video and audio to any usb storage device.
    And it is kinda strange there isn't something like this on the market, I think most of this stuff is for professionel users, because I do know some hd's which can record audio and video straight away.
    WYGIWYS.tv
    by The Midi Thief » Sun Mar 16, 2008 1:40 am
    This looks pretty interesting! So are you using the Pinnacle Video Transfer or do you know anybody who does? I want to know if it works well so there isn't any weird lag or inconsistencies.
    by vanakaru » Sun Mar 16, 2008 1:02 pm
    you could read this as well
    http://vjforums.com/showthread.php?t=23629
    g4jon
    maybe one of these?
    by g4jon » Thu Mar 20, 2008 9:56 pm
    check out these gizmos.
    http://www.dogcamsport.co.uk
    Code: Select all
    http://www.dogcamsport.co.uk/solid-state-mp4-recorder.htm
    Code: Select all
    http://www.dogcamsport.co.uk/me1-digital-bullet-camera-recorder.htm
    cheveria
    by cheveria » Sat Mar 22, 2008 12:35 am
    thanx g4jon,
    looks interesting,
    Did anyone try it yet?
    i love to know does it record sets well,
    + a screen to view what you have done,
    and it fits on cig pack thats how small it is. nice.
    love to try it first though.
    g4jon
    dv500
    by g4jon » Sat Mar 22, 2008 1:47 pm
    I have just got a dv-500. I will be doing tests after the easter hols... will report back on quality etc... watch this space.
    by The Midi Thief » Thu Apr 24, 2008 1:55 am
    I bought the Pinnacle Video Transfer. It's unfortunately not that great. I've recorded analog video to DV cameras before and it won't beat the DV quality. It seems like it has 50% compression problem (moving flat colored objects looks crappy) and 50% field problem. It looks really crappy in full size.I needed this device for two reasons: to record video in full size (to put on DVD) and to record audio and video at the same time. It works fine for making small videos to put on-line.
    g4jon
    dv-500
    by g4jon » Fri Apr 25, 2008 6:09 pm
    Hello all. Sorry its taken so long to update info on DV-500. I use this to record with a bullet cam on my motorcycle on track days. I will keep this brief as all tech specs can be got from the "Dogcamsport" website. It is very compact, ideal for recording sports as there is no HD. AS for recording live vj sets , its compact and easy to use but the quality is not great. The image is a bit blocky, not jerky it is 25fps. You probably would not want to re-use the footage you captured if Hi-res & Hi-def is your thing. If you are just a budding amateur like myself then its ok. If anyone wants a short clip of what it records like send me an email.
