modul8 working very slow in my laptop now ...
  • timothy_boreale
    by timothy_boreale » Thu Feb 28, 2008 6:27 am
    really need help from you ....
    i am use a mbp 1.5g ram ...
    run m8 with 16 clips which is 640*480 h264 mov . not big clips , each clip like 1-3mb
    modul8 preference i use media stored from 3 mbs .
    the problem is when i running with moduls like sequencer or chormakey ., it is start slow and slower ...
    and my cpu is 93% user , and memory only free around 10 mb
    someone call tell me what's going on /? and how can i fix it ??
  • DJSare
    by DJSare » Thu Feb 28, 2008 11:42 am
    Hello
    The h264 Code is very great and have a high compression.
    You PowerBook or MBP nead CPU to decompression the files.
    If many layer activatet, need many more CPU speed.
    If you have checke a less compression, i like the AnimationCode
    (this play great forward and backward, but nead a fast Harddisk)
    Find the balance: Harddiskspeed and CPU to optimize the System.
    I hope this can help you.
    (or have you update your System in the last Days and
    the Grafik update!!! If you say slow now)
    SARE :wink:
    by The Midi Thief » Tue Mar 04, 2008 10:12 am
    DJSare wrote:Hello
    Don't forget that Photo JPEG is the fastest recommended codec. These things are explained in the manual.
