apple intermediate codec
  • keptnahab
    by keptnahab » Fri Mar 07, 2008 5:21 pm
    hi
    anyone uses the "new" apple intermediate hd codec ?
    ive played around it with several formats on my mbp 2x2,33 ghz/4gb
    and on my macpro 8x3ghz/8gb/x1900xt. here are my subjective results:
    with the 8core ai really rocks, i can play files 4096x768 without drops
    which never really worked with pjpg before !
    also on the mbp it seems to run smoother, although the cpu usage seems
    to be enormous since the fan is always on full power during playback
    and the mbp gets really hot in seconds !
    it seems to be a good alternative to pjpg, especially with enough
    cpu power. you can access every frame with this codec (not like h264)
    so its possible to jump,scrub,play backwards.
    and it compresses to very small files with excellent quality !
    so, does anyone use this codec already for m8,and whats your experience?
    regards,
    mike
    the box said windows xp or better - so i bought a mac
    deepvisual
    Re: apple intermediate codec
    by deepvisual » Tue Mar 18, 2008 9:46 am
    I was recommended to use it for catalyst by an experienced operator.
  • RickRobiN
    by RickRobiN » Tue Mar 18, 2008 10:05 pm
    really good information this. thanks for sharing!
    cheers RR
  • toby
    by toby » Fri Apr 11, 2008 7:48 pm
    Does anyone know how to set the quality with Intermedia Compression.
    In QickTime Export & Compressor its fixed on 50%.
    deepvisual
    by deepvisual » Mon May 12, 2008 1:13 pm
    this works in AFX..
    set codec to photojpeg.
    set compression
    switch to AIC
    it remembers the compression setting...
  • RickRobiN
    by RickRobiN » Wed May 21, 2008 12:25 am
    So what will be better (safer/faster/etc) h264 @ 100% or AIC @ 100 %..
    talking about 1080p multiscreen set up with a mac pro 08
    (edit under heavy processor load (during AE renders etc) quicktime h264 plays smoother. already did a gig without probs with h264, so not sure to switch to AIC)
    cheers RR
  • keptnahab
    by keptnahab » Fri May 23, 2008 3:40 pm
    no need to switch to aic as long as you only play your movies,
    only if you want to jump and scrub in your movies aic is better
    at least this works for me.
  • RickRobiN
    by RickRobiN » Fri May 23, 2008 4:11 pm
    thanks for your answer :)
  • RickRobiN
    by RickRobiN » Sun Jun 01, 2008 7:32 pm
    AIC looks much better than H264 with footage with a lot of gradient.
    deepvisual
    by deepvisual » Mon Jun 02, 2008 9:35 am
    I've been getting odd artifacts on AIC.
    blue backgrounds have streaks ??
  • maxus
    by maxus » Tue Jun 03, 2008 11:47 am
    hi.. i'm trying to choose codec too... i've been using apple pro res but it shutters when i try to change the clip speed. my videos are one minute long 3072*768
    what's the best codec?
