Sending a Modul8 video output to another Modul8 (2 laptops)
    Anome
    by Anome » Sun Mar 09, 2008 11:06 pm
    Is there a way to send the video output of a laptop which uses Modul8 to a second laptop (which also uses Modul8 and acts as a master) through Ethernet or Firewire ?
    Cheers.
  • VJnutcracker
    by VJnutcracker » Sun Mar 09, 2008 11:10 pm
    I dont think modul8 outputs via firewire.
    You can do it by using an analog to firewire device like a camcorder with analog in and dv passthrough, or a formac dv studio analog to dv converter amd plug the firewire into your master computer
    wygiwys
    by wygiwys » Mon Mar 10, 2008 4:42 pm
    If you have an analog output, you can use the 'Miglia Director's Cut' or a camcorder with dv-in
    Modul8 can't send out via firewire.
    But I don't think that's what you mean. I'm also looking for afunction to send you output to another computer (a feed which is already rendered)
    What You Get Is What You See
    WYGIWYS.tv
    Anome
    by Anome » Mon Mar 10, 2008 4:53 pm
    Yeah that's exactly what i meant : a software solution instead an hardware one (despite the Miglia Director's Cut seems very great, cheers).
  • VJnutcracker
    by VJnutcracker » Mon Mar 10, 2008 8:14 pm
    In that case the answer to your question is no.
  • rsarosi
    Modul8 over Firewire
    by rsarosi » Wed Mar 12, 2008 6:09 pm
    I posted a comment about the Modul8 over Firewire issue.
    My question is: Is it possible?
    See the details here:
    http://www.garagecube.com/forum/viewtopic.php?t=2100
